跳转到主内容
Linear Rail V2/V3 Endstop Install
你所需要的
  1. Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: 步骤 1 中的图像 1,3 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: 步骤 1 中的图像 2,3 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: 步骤 1 中的图像 3,3
    • M3 Sliding T-Nut
    • Slide in the M3 T-Nut toward the middle of the printer
    • M3X12 BHCS & M3 FLAT WASHERS
    • M3x10 FHCS
    • Adjustable Endstop Mount A
    • Adjustable Endstop Mount B
    • Tighten the M3 screw into the T-Nut
  2. Linear Rail V2/V3 Endstop Install, Endstop install: 步骤 2 中的图像 1,2 Linear Rail V2/V3 Endstop Install, Endstop install: 步骤 2 中的图像 2,2
    • Adjust endstop mount until it is square with the Linear rail
    • Remove stock endstop board form Creality mount and Reuse the stock screws to mount the endstop as shown
  3. Linear Rail V2/V3 Endstop Install, Setting endstop position: 步骤 3 中的图像 1,2 Linear Rail V2/V3 Endstop Install, Setting endstop position: 步骤 3 中的图像 2,2
    • Use M3x12 BHCS to adjust the endstop position, so the nozzle tip is even with the front edge of the bed when the end stop is triggered
    • Check the clearance between the motor and the linear adaptor. When the bed is all the way back against the endstop. There should be a 1-2 mm gap when the endstop is triggered.
结论
AJ Pereira
于05/29/20注册
2,735 声望
创作了16篇指南
团队
Tiny Machines 3D Tiny Machines 3D 的会员
Community
5 名成员
创作了41篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 27
过去 30 天: 77
总计 1,882
