跳转到主内容
Lightahead DV328 Arrow Button Replacement
你所需要的
  1. Lightahead DV328 Arrow Button Replacement, Arrow Button: 步骤 1 中的图像 1,3 Lightahead DV328 Arrow Button Replacement, Arrow Button: 步骤 1 中的图像 2,3 Lightahead DV328 Arrow Button Replacement, Arrow Button: 步骤 1 中的图像 3,3
    • Use a spudger to remove the two screw covers.
    • Remove the two Phillips #0 screws.
  2. Lightahead DV328 Arrow Button Replacement: 步骤 2 中的图像 1,3 Lightahead DV328 Arrow Button Replacement: 步骤 2 中的图像 2,3 Lightahead DV328 Arrow Button Replacement: 步骤 2 中的图像 3,3
    • Once you are able to lift the cover up, you will then be able to pry off the lens which will allow for the device to open more.
    • Take off the lens cover. Be careful not to pull the device open too much otherwise you will snap it in half since it is made of plastic.
    • Once you have this up, pull up the cover and you will now be able to work on the arrow key button
  3. Lightahead DV328 Arrow Button Replacement: 步骤 3 中的图像 1,3 Lightahead DV328 Arrow Button Replacement: 步骤 3 中的图像 2,3 Lightahead DV328 Arrow Button Replacement: 步骤 3 中的图像 3,3
    • Lay the camcorder on its side. The arrow key button is now in full view.
    • There is a small green piece locking in the arrow key button. Once you remove that, the piece will be able to come out.
    • Gently push on the button and it will come out of the device. Replace as needed
结论
团队
USF Tampa, Team 10-2, Remmell Spring 2016 USF Tampa, Team 10-2, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G2
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 115
