跳转到主内容
LifePrint 3x4.5 Charging Port Replacement
你所需要的
  1. LifePrint 3x4.5 Charging Port Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Charging Port Replacement, Inner Cover: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Charging Port Replacement, Charging Port: 步骤 3 中的图像 1,1
    • Remove the five Phillips #0 screws from the outer edge of the motherboard indicated by the copper color surrounding the screws' housing.
  4. LifePrint 3x4.5 Charging Port Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a soldering iron to heat up the soldering joints surrounding the port that connects the device to the circuit board.
    • After the solder is heated up use the de-soldering wick to absorb the solder holding the socket to the circuit board .
    • After the solder is removed use the tweezers to remove the port from the circuit board.
结论
团队
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 UMass Dartmouth, Team S1-G2, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S1G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 374
