简介
Here is how to get access to the battery in the Lezyne Micro drive using a vice and ratchet sockets (no special tools).
I found that my brilliant new light that I bought from the UK did not charge, so rather then paying the ridiculous amounts of postage to claim warranty, I thought I would try to fix it myself.
你所需要的
You can see where the electronics slides into.
You can see how it is held in with friction from the raised plastic bevel. If you wish to make it easier to disassemble, file the friction bevel down. Don't file down the keying semi circular bevel.
The last picture shows the plastic filed down.
To reassemble your device, just put it back together.
11等其他人完成本指南。
30条评论
Thanks just repaired my Lezyne Macro Drive front light. Light would flicker, just needed to re-solder the top left resistor shown in step 4.
you can just push the electronics and battery out with your thumb. Usually the issue with these batteries is the battery contact gets slightly corroded. Clean it with battery cleaner, and twist the battery a bit for a new and clean connection.
