你所需要的
Remove the paper tray
Remove the screw securing the right cover to the front of the printer frame.
Open the memory access cover that is attached to the right cover
Remove the two screws securing the right cover to the RIP shield.
Slightly lift the printer, slide the right cover forward, and pull it out and away from the printer
Remove the screw securing the left cover to the front of the printer frame.
Release the Two tabs on the bottom of the cover.
Pull the cover forward, and remove it from the printer.
Open rear door.
Pull the exit door upward to release the hinges, and remove.
Remove the two screws securing the rear cover.
Remove the cover.
Remove the three screws from the Left Mounting Bracket
Two different ways to the next step, dependent on experience and/or confidence.
Move the the Mounting Bracket over while extending the Stapler Cable out of the way, The Stapler cable does not have to disconnected.
Remove the Stapler Cable and Mounting bracket from the printer frame while feeding the cable through the redrive unit and printer frame.
Using a pair of pliers, squeeze the nylon mounts to dislodge the stapler connector, and remove the cable.
Remove the three screws from the Right mounting bracket.
Remove the Two screws, and then disconnect the reverse solenoid.
Do not disconnect the reverse solenoid cable from the controller board.
Remove the Six screws securing the redrive assembly.
Disconnect the cable JEXIT1 from the controller board.
Disconnect the Two cables.
Remove the Two screws securing the fuser.
