跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Ink cartridges allow the printer to print using the ink in the cartridges. The colors included are black, yellow, blue and pink.
  1. Lift the scanning unit, exposing the print head. Lift the scanning unit, exposing the print head.
    • Lift the scanning unit, exposing the print head.
  2. Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Lift the frame to expose the ink cartridges.
    • Lift the frame to expose the ink cartridges.
  5. Push the button located above the designated ink cartridge until it pops out.
    • Push the button located above the designated ink cartridge until it pops out.
  6. Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  7. Close the scanner unit. Close the scanner unit.
    • Close the scanner unit.
结论
Once your ink cartridges are in place, your printer should now print high-quality documents.
2等其他人完成本指南。
Omar
于2013年01月23日注册
111 信誉积分
创作了2篇指南
团队
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G38
4 名成员
创作了4篇指南
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 2,736
