跳转到主内容
Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: 步骤 1 中的图像 1,2 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: 步骤 1 中的图像 2,2
    • Lift the scanning unit, exposing the print head.
  2. Lexmark Intuition S505 Ink Cartridges Replacement: 步骤 2 中的图像 1,1
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. Lexmark Intuition S505 Ink Cartridges Replacement: 步骤 3 中的图像 1,1
    • Lift the frame to expose the ink cartridges.
  4. Lexmark Intuition S505 Ink Cartridges Replacement: 步骤 4 中的图像 1,1
    • Push the button located above the designated ink cartridge until it pops out.
  5. Lexmark Intuition S505 Ink Cartridges Replacement: 步骤 5 中的图像 1,1
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  6. Lexmark Intuition S505 Ink Cartridges Replacement: 步骤 6 中的图像 1,2 Lexmark Intuition S505 Ink Cartridges Replacement: 步骤 6 中的图像 2,2
    • Close the scanner unit.
结论
Once your ink cartridges are in place, your printer should now print high-quality documents.
3等其他人完成本指南。
Omar
于01/23/13注册
132 声望
创作了2篇指南
团队
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G38
4 名成员
创作了8篇指南
3指南评论
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - 回复
Merci beaucoup pour tout
Bouzebiba - 回复
Merci beaucoup pour votre compréhension et bonne journée également bisous 😚
Bouzebiba - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 3,480
