跳转到主内容
加入维修社区 - 创建账户
LexiBook Tablet One Camera Replacement
你所需要的
    1. LexiBook Tablet One Camera Replacement, Camera: 步骤 1 中的图像 1,3 LexiBook Tablet One Camera Replacement, Camera: 步骤 1 中的图像 2,3 LexiBook Tablet One Camera Replacement, Camera: 步骤 1 中的图像 3,3
      • Find the seam in the casing. Insert the blue plastic opening tool, and slide to either side carefully undoing the clips. The clips are hidden within the casing and are spaced roughly 1.5 in. apart.
      • When opening the device, be wary of the speaker wire. It is best to open the device from the right side with the camera oriented to the top.
      询问修复机器人
      添加评论
    2. LexiBook Tablet One Camera Replacement: 步骤 2 中的图像 1,2 LexiBook Tablet One Camera Replacement: 步骤 2 中的图像 2,2
      • Insert a spudger between the speaker and the casing. Gently pop the speaker out, and set the panel to the side.
      询问修复机器人
      添加评论
    3. LexiBook Tablet One Camera Replacement: 步骤 3 中的图像 1,1
      • Using a plastic spudger, wedge the tool between the battery and LCD. Repeatedly gouge and work around the edges of the battery until the adhesive breaks free. You will have to apply generous pressure, as long as you push horizontally the components should not be further damaged.
      • Be careful not to damage any wires or to puncture the battery casing when peeling the adhesive.
      • A similar flat tool can be used in place of a plastic spudger.
      询问修复机器人
      添加评论
    4. LexiBook Tablet One Camera Replacement: 步骤 4 中的图像 1,3 LexiBook Tablet One Camera Replacement: 步骤 4 中的图像 2,3 LexiBook Tablet One Camera Replacement: 步骤 4 中的图像 3,3
      • Remove the ribbon cable leading to the camera by carefully using a flat headed tool to open the ribbon clip.
      • Gently slide the ribbon cable out while holding the clip open.
      询问修复机器人
      添加评论
    5. LexiBook Tablet One Camera Replacement: 步骤 5 中的图像 1,1
      • When inserting your new camera, maintain the clip's open position and slide the new ribbon cable in.
      • It is imperative the clip not close partially when installing the new ribbon, or the new cable can be damaged.
      • When the ribbon can go no further into the clip, close the clip.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jordan
于03/11/15注册
650 声望
创作了4篇指南
团队
Colorado Springs, Team 2-5, Panko Spring 2015 Colorado Springs, Team 2-5, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G5
3 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 480
