跳转到主内容
加入维修社区 - 创建账户
Levoit Core 300-RAC Control Board Replacement
你所需要的
  1. Levoit Core 300-RAC Control Board Replacement, Control Board: 步骤 1 中的图像 1,3 Levoit Core 300-RAC Control Board Replacement, Control Board: 步骤 1 中的图像 2,3 Levoit Core 300-RAC Control Board Replacement, Control Board: 步骤 1 中的图像 3,3
    • Make sure the device is turned off and unplugged before disassembling it.
    • Insert the Jimmy between the gray grille cover and the top of the device.
    • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
    • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
    • Remove the grille cover gently as it is connected by a ribbon cable.
    • Be careful not to put too much strain on the ribbon cable as it may break.
    询问修复机器人
    添加评论
  2. Levoit Core 300-RAC Control Board Replacement: 步骤 2 中的图像 1,3 Levoit Core 300-RAC Control Board Replacement: 步骤 2 中的图像 2,3 Levoit Core 300-RAC Control Board Replacement: 步骤 2 中的图像 3,3
    • Squeeze the tab on the connector to release the bundled cable from the control board.
    • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
    询问修复机器人
    添加评论
  3. Levoit Core 300-RAC Control Board Replacement: 步骤 3 中的图像 1,2 Levoit Core 300-RAC Control Board Replacement: 步骤 3 中的图像 2,2
    • Gently bend the gray plastic cover to release the control board.
    • There are several hard tabs holding the control board in place.
    询问修复机器人
    添加评论
  4. Levoit Core 300-RAC Control Board Replacement: 步骤 4 中的图像 1,3 Levoit Core 300-RAC Control Board Replacement: 步骤 4 中的图像 2,3 Levoit Core 300-RAC Control Board Replacement: 步骤 4 中的图像 3,3
    • Lift the control board from the gray plastic cover.
    • Take note of the orientations of the buttons, as that will help during reassembly.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Mustafa
于11/03/23注册
259 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-6, Petersen Fall 2023 UMass Dartmouth, Team 1-6, Petersen Fall 2023 的会员
UMASSD-PETERSEN-F23S1G6
5 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 68
总计 1,735
