简介
This guide will show to replace the neck connection that combines the neck to the main body of the guitar.
你所需要的
Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
Push level, this will detach the back of the guitar from the front.
Carefully remove the back of the body
The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
The neck connector may be stuck to the back so be sure to detach it before fully pulling
Remove the 10 screws (each are 1 cm long) on the back of the neck using a T-10 Torx security screwdriver.
Remove the back of the neck.
2等其他人完成本指南。
