简介
This guide will show how to replace the guitar's battery pack. The battery pack supplies power to the controller and houses the two AA batteries required for the controller.
工具
无需工具。
配件
无需配件。
  1. Remove batteries
    • Remove batteries
  2. Remove void warranty sticker The sticker is covering a torx screw
    • Remove void warranty sticker
      • The sticker is covering a torx screw
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long. Push level, this will detach the back of the guitar from the front. Carefully remove the back of the body
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
      • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
      • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  5. Gently move the capacitor around until it breaks off Gently move the capacitor around until it breaks off
    • Gently move the capacitor around until it breaks off
  6. Solder on the new capacitor.
    • Solder on the new capacitor.
结论
另外一个人完成了本指南。
Chris
于2013年10月18日注册
752 信誉积分
创作了6篇指南
Yo can you help for the drum set I saw two wires detached ( red an black) when I I opened it up. Please email me so I can send a picture djcab361@outlook.com
Chris - 回复
浏览统计数据:
过去的24小时: 4
过去的7天: 19
过去的30天: 81
总计 4,668
