跳转到主内容
Les Paul Guitar Pickup Replacement
你所需要的
  1. Les Paul Guitar Pickup Replacement, Pickup: 步骤 1 中的图像 1,3 Les Paul Guitar Pickup Replacement, Pickup: 步骤 1 中的图像 2,3 Les Paul Guitar Pickup Replacement, Pickup: 步骤 1 中的图像 3,3
    • Loosen the guitar strings using a string winder.
    • The three strings closest unwind clockwise and the three farther away unwind counterclockwise.
    • Using a coin, carefully begin unscrewing and removing the tailpiece.
    • You can use a flat head screwdriver, but it will damage the finish on your tailpiece.
    • Remove the tailpiece by completely unscrewing it from the metal inserts and then gently lifting the assembly out of the body and set off to the side.
  2. Les Paul Guitar Pickup Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the eight screws keeping the pickups in place.
    • All screws are the same size.
  3. Les Paul Guitar Pickup Replacement: 步骤 3 中的图像 1,3 Les Paul Guitar Pickup Replacement: 步骤 3 中的图像 2,3 Les Paul Guitar Pickup Replacement: 步骤 3 中的图像 3,3
    • Note which color wire is coming out of each pickup.
    • Gently flip over your guitar and put it on a soft towel or other soft material. Take off the control cavity cover.
    • Desolder the wires of the pickup from the terminal that is touching the back of the potentiometer, or pot.
    • A potentiometer is what the pickups are wired to that allow the player to have on-board control of their volume and tone. Terminals are the parts on a potentiometer that you solder the wires to.
  4. Les Paul Guitar Pickup Replacement: 步骤 4 中的图像 1,1
    • Flip over your guitar again. Thread the wire of the new pickup through the body to the control cavity and screw in the pickup using the Phillips #0 screwdriver.
    • Check what color wire is coming from each pickup.
    • For these kinds of pickups, the neck pickup magnet should face the neck and the bridge pickup magnets should face the bridge.
  5. Les Paul Guitar Pickup Replacement: 步骤 5 中的图像 1,1
    • Do not touch the soldering iron, or let it touch anything but the solder and wires.
    • The pickup wire should have multiple wires inside it. Check with the manufacturer which wire is which.
    • Solder the new ground wires to the back of the volume pots or to the terminal touching the back of the pot.
  6. Les Paul Guitar Pickup Replacement: 步骤 6 中的图像 1,1
    • Do not touch the metal parts of the soldering iron or the solder after melting it, they will burn you.
    • Relative to the output jack, the bottom row is for the bridge pickup and the top row is for the neck pickup.
    • Identify your hot wires and volume pots and solder the hot wire to the center terminal of the wires corresponding pot.
  7. Les Paul Guitar Pickup Replacement: 步骤 7 中的图像 1,1
    • Screw back on the control cavity cover and flip over your guitar.
    • Reattach the tailpiece and tune your guitar.
    • Raise and lower the pickups as desired using the two screws on the sides of the pickup rings.
结论
Plug in your beloved guitar and rock out with your fresh pickups
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 32
总计 964
