简介
Here, we will describe how to dissemble your camera in order to properly replace the lens cover.
你所需要的
Unscrew the two small screws on the black side panel of the camera using a PH00 screwdriver. Remove the part.
另外一个人完成了本指南。
一条评论
I found that additional steps are needed between steps 2 and 3 to remove 5 additional screws before the front panel can be removed.
Was my Olympus 850 SW different from the one repaired in that tutorial?
I took pictures that I could insert in the tutorial, but did not find how to do it.
Michel
