跳转到主内容
Lenovo bluetooth mouse N6901A disassembly
你所需要的
  1. Lenovo bluetooth mouse N6901A disassembly, Mouse: 步骤 1 中的图像 1,1
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. Lenovo bluetooth mouse N6901A disassembly: 步骤 2 中的图像 1,2 Lenovo bluetooth mouse N6901A disassembly: 步骤 2 中的图像 2,2
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Lenovo bluetooth mouse N6901A disassembly: 步骤 3 中的图像 1,2 Lenovo bluetooth mouse N6901A disassembly: 步骤 3 中的图像 2,2
    • At this point, you have separated the mouse cover
  4. Lenovo bluetooth mouse N6901A disassembly: 步骤 4 中的图像 1,1
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  5. Lenovo bluetooth mouse N6901A disassembly: 步骤 5 中的图像 1,2 Lenovo bluetooth mouse N6901A disassembly: 步骤 5 中的图像 2,2
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
结论
2等其他人完成本指南。
Shinn Chyang Chen
于09/14/11注册
2,953 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 5,633
