简介
This guide will show you how to replace the electric fan on your Lenovo Z70-80 laptop.
你所需要的
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Remove the two Phillips #0 screws from the bottom panel.
Slide the panel down slightly, and then lift to pull it off.
Remove the three 6mm Phillips #0 screws from the fan.
Disconnect the fan from the motherboard by pulling up on the plug.
另外一个人完成了本指南。
