跳转到主内容
Lenovo Yoga Tablet 2 830-F Motherboard Replacement
你所需要的
  1. Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw on the back fo the device with a Phillips #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: 步骤 2 中的图像 1,2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the six 3mm screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Remove ZIF connectors connecting the boards to the electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: 步骤 3 中的图像 2,2
    • Replace the motherboard with the new motherboard.
    • Be careful not to damage the ribbon cables when reassembling the device.
结论
Charles Rhode
于09/28/17注册
594 声望
创作了3篇指南
团队
USF Tampa, Team S2-G4, Nance Fall 2017 USF Tampa, Team S2-G4, Nance Fall 2017 的会员
USFT-NANCE-F17S2G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 1,963
