跳转到主内容
Lenovo Yoga Tablet 2 830-F Camera Replacement
你所需要的
  1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: 步骤 1 中的图像 1,2 Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: 步骤 1 中的图像 2,2
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Camera Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga Tablet 2 830-F Camera Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga Tablet 2 830-F Camera Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips Screwdriver #00 bit remove the 6 screws.
    • Using the Phillips Screwdriver #00 bit remove the 3 screws.
    • After removing all the screws, disconnect the ribbon cables.
    • Disconnect the ZIF connectors.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Camera Replacement: 步骤 3 中的图像 1,3 Lenovo Yoga Tablet 2 830-F Camera Replacement: 步骤 3 中的图像 2,3 Lenovo Yoga Tablet 2 830-F Camera Replacement: 步骤 3 中的图像 3,3
    • After removing the motherboard and antennas the camera module is located on the right as marked in red.
    • Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
    • The camera module is also held in place with adhesive so gently remove.
结论
另外一个人完成了本指南。
Mario Gjyli
于09/28/17注册
449 声望
创作了3篇指南
团队
USF Tampa, Team S2-G4, Nance Fall 2017 USF Tampa, Team S2-G4, Nance Fall 2017 的会员
USFT-NANCE-F17S2G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 11
总计 659
