跳转到主内容
Lenovo Yoga Tablet 2 830-F Antenna Replacement
你所需要的
  1. Lenovo Yoga Tablet 2 830-F Antenna  Replacement, Wifi Antenna: 步骤 1 中的图像 1,2 Lenovo Yoga Tablet 2 830-F Antenna  Replacement, Wifi Antenna: 步骤 1 中的图像 2,2
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Antenna  Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga Tablet 2 830-F Antenna  Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga Tablet 2 830-F Antenna  Replacement: 步骤 2 中的图像 3,3
    • Remove the six screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the three screws on the back of the secondary board with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components.
    • Remove the ZIF connectors connecting the boards to the other electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Antenna  Replacement: 步骤 3 中的图像 1,1
    • Disconnect the antenna module from the motherboard.
结论
Mario Gjyli
于09/28/17注册
449 声望
创作了3篇指南
团队
USF Tampa, Team S2-G4, Nance Fall 2017 USF Tampa, Team S2-G4, Nance Fall 2017 的会员
USFT-NANCE-F17S2G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 5
过去 30 天: 14
总计 950
