跳转到主内容
Lenovo Yoga Tablet 10 Camera PCB Replacement
你所需要的
  1. Lenovo Yoga Tablet 10 Camera PCB Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 2 中的图像 1,1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Camera PCB Replacement, Back Camera: 步骤 4 中的图像 1,2 Lenovo Yoga Tablet 10 Camera PCB Replacement, Back Camera: 步骤 4 中的图像 2,2
    • Remove one 5mm screw using the Phillips #00 Screwdriver.
  5. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 5 中的图像 1,3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 5 中的图像 2,3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 5 中的图像 3,3
    • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
  6. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 6 中的图像 1,1
    • Remove one 5mm screw with the Phillips #00 screwdriver.
  7. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 7 中的图像 1,3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 7 中的图像 2,3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
  8. Lenovo Yoga Tablet 10 Camera PCB Replacement, Camera PCB: 步骤 8 中的图像 1,1
    • Remove the four 1 mm screws with a Phillips #00 Screwdriver.
  9. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 9 中的图像 1,2 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to disconnect the ribbon wire by applying a force upwards.
  10. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 10 中的图像 1,2 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to lift up the foil.
    • The foil may tear.
  11. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 11 中的图像 1,2 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 11 中的图像 2,2
    • Use the tweezers to lift the black tape from the corner of the printed circuit board.
  12. Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 12 中的图像 1,3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 12 中的图像 2,3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 步骤 12 中的图像 3,3
    • Flip the board 180 degrees towards you using the tweezers.
结论
Juan Benjamin
于01/24/19注册
490 声望
创作了4篇指南
团队
Cal Poly, Team S2-G6, White Winter 2019 Cal Poly, Team S2-G6, White Winter 2019 的会员
CPSU-WHITE-W19S2G6
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 312
