跳转到主内容
Lenovo Yoga Tablet 10 Back Camera Replacement
你所需要的
  1. Lenovo Yoga Tablet 10 Back Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 2 中的图像 1,1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Back Camera Replacement, Back Camera: 步骤 4 中的图像 1,2 Lenovo Yoga Tablet 10 Back Camera Replacement, Back Camera: 步骤 4 中的图像 2,2
    • Remove one 5mm screw using the Phillips #00 Screwdriver.
  5. Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 5 中的图像 1,3 Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 5 中的图像 2,3 Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 5 中的图像 3,3
    • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
  6. Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 6 中的图像 1,1
    • Remove one 5mm screw with the Phillips #00 screwdriver.
  7. Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 7 中的图像 1,3 Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 7 中的图像 2,3 Lenovo Yoga Tablet 10 Back Camera Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
结论
另外一个人完成了本指南。
Juan Benjamin
于01/24/19注册
490 声望
创作了4篇指南
团队
Cal Poly, Team S2-G6, White Winter 2019 Cal Poly, Team S2-G6, White Winter 2019 的会员
CPSU-WHITE-W19S2G6
4 名成员
创作了7篇指南
一条评论
“To reassemble your device, follow these instructions in reverse order. “ Including unripping the power switch tail, which is soldered to the board. Look at the last picture!
The camera/speaker assembly cannot be removed without unsoldering this tail.
Fixin Ma Stuff - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 472
