简介
If you are following this guide, that means your kickstand lock is broken or causing you issues on your Lenovo Yoga Tab 3 8. Before starting to work on your device, it is advised to back up any important files just in case something happens. You will want to make sure you have the device powered off to prevent harming yourself or damaging your hardware. To make reassembly easier, be sure to avoid misplacing the small screws by keeping track of them as you go.
你所需要的
Locate the four 2mm screws that secure the lock and remove them with a PH00 screwdriver.
