简介
If you are following this guide, that means your battery is dead or causing you issues on your Lenovo Yoga Tab 3 8. If your device is still capable of running, back up your files and make sure the device is powered off before you begin. To make reassembly easier, be sure to avoid misplacing the small screws by keeping track of them as you go.
你所需要的
With the tablet oriented screen side down and hinge opposite of you, locate the black plastic piece on the top right.
Remove the upper 4mm and lower 3mm screws with a PH00 screwdriver.
在这个步骤中使用的工具:Tweezers$4.99
At the opposite end of the hinge, locate the silver metal bracket over the wires coming from the end of the hinge. Remove the two 3mm screws with a PH00 screwdriver. Lift the bracket off with your fingers.
Removing the bracket will expose two silver connectors at the ends of the wires coming from the end of the hinge. Use tweezers to carefully lift off the two silver connectors.
Locate the smaller metal wire bracket guiding the wires coming from the end of the hinge. Remove the single black 2mm screw with a PH00 screwdriver. Lift the bracket off with your fingers.
10等其他人完成本指南。
4条评论
In case please make a vedio and upload in YouTube that I can replaced my lenovo battery easily without any problem.
My yoga tablet battery appears to be dead. Is it ok to leave it in the tab for a few weeks?
Please where i can buy this battery…
