跳转到主内容
Lenovo Yoga Tab 3 8 Back Cover Replacement
你所需要的
  1. Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Back Cover Replacement: 步骤 3 中的图像 1,3 Lenovo Yoga Tab 3 8 Back Cover Replacement: 步骤 3 中的图像 2,3 Lenovo Yoga Tab 3 8 Back Cover Replacement: 步骤 3 中的图像 3,3
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
结论
3等其他人完成本指南。
Nicklaus Krems
于09/25/17注册
1,049 声望
创作了8篇指南
团队
USF Tampa, Team S16-G2, Eyestone Fall 2017 USF Tampa, Team S16-G2, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S16G2
4 名成员
创作了16篇指南
一条评论
Had put the SIM in the Memory card slot, instructions came in handy.
Brijesh Rajashekara - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 2,851
