跳转到主内容
Lenovo Yoga Tab 3 10 Camera Replacement
你所需要的
  1. Lenovo Yoga Tab 3 10 Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 2 中的图像 3,3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 3 中的图像 1,3 Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 3 中的图像 2,3 Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 3 中的图像 3,3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Camera Replacement, Camera: 步骤 4 中的图像 1,3 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: 步骤 4 中的图像 2,3 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: 步骤 4 中的图像 3,3
    • Remove the 3 screws from the auxiliary port cover.
    • Use the spudger to gently push the auxiliary module out of the way.
    • Remove the detachable plastic latch located in front of the hinge.
  5. Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to gently remove the hinge.
  6. Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the kickstand away from the frame.
    • The battery is located inside of the kickstand. Ensure proper handling and care.
  7. Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 7 中的图像 1,2 Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 7 中的图像 2,2
    • Use the pointed end of a spudger to push in the camera's locking mechanism.
    • Upon releasing the camera lock lift the camera out and locate the three screws.
  8. Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 8 中的图像 1,3 Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 8 中的图像 2,3 Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 8 中的图像 3,3
    • Use a J000 Philips screwdriver to remove the three screws.
    • Remove the camera cover that seals the camera case.
    • Remove the camera from the shell.
  9. Lenovo Yoga Tab 3 10 Camera Replacement: 步骤 9 中的图像 1,1
    • Separate the camera from its casing.
结论
2等其他人完成本指南。
Phanudej
于02/20/17注册
1,184 声望
创作了5篇指南
团队
USF Tampa, Team S3-G2, Sullivan Spring 2017 USF Tampa, Team S3-G2, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S3G2
4 名成员
创作了18篇指南
一条评论
Thanks for describing in details with bit and peaces very neatly and clearly. I fix the problem of my Lenovo Yoga 3 with help of this. Great job you have done.. keep it up… Sisira
Sisira Kumara - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 4,121
