你所需要的
Locate the screws in the motherboard the wire cover assembly and the speakers.
Use the J000 screwdriver to remove the screws on the motherboard, the wire cover, and the two speakers.
Disconnect the wifi connector on the motherboard.
13等其他人完成本指南。
一条评论
Dear @phanudej ,
I liked your post. I’d have a remark and a question. I made a mistake during the maintanance; with wich I killed a part of the MOBO. So dear users my advice if you want to connect the LCD connector remove the battery before… I had never this issue but now happened. (the device was switched off)
Could you please take a photo of the powerstage of the LCD (I think it should be that) So between the inductor (100; 10uH coil) and an capacity there is a component I do not know what is it (it smoked away) I assume it is a diode…?! They are in the white rectangle near the LCD connector
Thanks in advance
Best regards
