跳转到主内容
Lenovo Yoga C930-13IKB SSD Replacement
你所需要的
  1. Lenovo Yoga C930-13IKB SSD Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB SSD Replacement: 步骤 2 中的图像 1,2 Lenovo Yoga C930-13IKB SSD Replacement: 步骤 2 中的图像 2,2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB SSD Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga C930-13IKB SSD Replacement: 步骤 3 中的图像 2,2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB SSD Replacement, SSD: 步骤 4 中的图像 1,1
    • Remove the screw ( 2 mm with a 5 mm head) that connect the SSD to the motherboard using a Phillips #00 screwdriver.
  5. Lenovo Yoga C930-13IKB SSD Replacement: 步骤 5 中的图像 1,1
    • Pinch the left side of the SSD card.
    • Pull gently to the left, horizontal to the laptop.
结论
另外一个人完成了本指南。
Hanna Lazkani
于01/23/20注册
788 声望
创作了3篇指南
团队
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 的会员
CPSU-WHITE-W20S19G5
4 名成员
创作了16篇指南
3条评论
I need to remove the stripped screw on the SSDs non-slot-end because Lenovo tightened it down with a military grade drill. To replace, it wasn’t mentioned which size screw was there.
John Tullos - 回复
Ty for the info but I'm looking to get windows installed onto the blank new hard drive so I can actually run and use it, lol! Unfortunately, the "automatic" registration process didn't work and my product key isn't to be found. In fact, my Microsoft account doesn't even have it registered as a device. But it does have it as a device I loaded apps from the Play Store though. So, there's proof it existed. Anywho, I'm stuck trying to get Windows on it before I re-install the hard drive. Any ideas are more than welcome! Thanks, M.H.
Mac Daditink - 回复
Good guide. I took the following steps and it went quickly and smoothly. Less than an hour start to finish:
1. I purchased a Samsung 980 (not Pro, but should also work).
2. Disabled bitlocker on my old SSD. I also backed up the key for future ref.
3. Downloaded and installed the Samsung SSD Magician and migration tools.
4. Put the new SSD into an external enclosure ($18 on Amazon).
5. Ran the migration software and copied my windows 11 to the new SSD.
6. Shutdown the laptop and swapped the SSDs.
7. Rebooted into windows.
8. Ran the Samsung Magician software and updated the SSD firmware.
9. Done and perfect.
Thomas Harding - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 65
总计 5,337
