跳转到主内容
Lenovo Yoga C930-13IKB Back Cover Replacement
你所需要的
  1. Lenovo Yoga C930-13IKB Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Back Cover Replacement: 步骤 2 中的图像 1,2 Lenovo Yoga C930-13IKB Back Cover Replacement: 步骤 2 中的图像 2,2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Back Cover Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga C930-13IKB Back Cover Replacement: 步骤 3 中的图像 2,2
    • Carefully lift the cover off with your hands.
结论
2等其他人完成本指南。
Hanna Lazkani
于01/23/20注册
788 声望
创作了3篇指南
团队
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 的会员
CPSU-WHITE-W20S19G5
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 67
总计 2,808
