跳转到主内容
Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement
你所需要的
  1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 2 中的图像 3,3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: 步骤 3 中的图像 1,3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: 步骤 3 中的图像 2,3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: 步骤 3 中的图像 3,3
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 4 中的图像 1,2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 4 中的图像 2,2
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 5 中的图像 1,1
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
  7. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Fingerprint Sensor: 步骤 7 中的图像 1,1
    • Remove the 3mm Phillips #00 Screw to loosen the sensor.
  8. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 8 中的图像 1,1
    • Lift up the cover on the fingerprint sensor using the iFixit Opening Tool and remove the cover from the sensor.
  9. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 9 中的图像 1,1
    • Flip up the cable connector tab using the iFixit Opening Tool to release the ribbon wire.
  10. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 10 中的图像 1,1
    • Unplug the ribbon wire from the sensor to completely free the sensor.
  11. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: 步骤 11 中的图像 1,1
    • Lift the fingerprint sensor with the iFixit Opening Tool and remove it from the device.
结论
Alyssa McCulloch
于01/24/19注册
1,906 声望
创作了9篇指南
团队
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 的会员
CPSU-WHITE-W19S2G3
4 名成员
创作了29篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 582
