跳转到主内容
Lenovo Yoga 910-13IKB Wi-Fi Card Replacement
你所需要的
  1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Battery: 步骤 2 中的图像 1,1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 步骤 3 中的图像 1,3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 步骤 3 中的图像 2,3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 步骤 3 中的图像 3,3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 1,1
    • Remove the single 1 mm screw at left of Wi-Fi card with a Phillips #0 screwdriver.
  5. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 步骤 5 中的图像 2,2
    • Pull the Wi-Fi card out of the slot on the motherboard.
    • It is still connected to the coaxial cables so don't yank it out or those connections will break.
  6. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 步骤 6 中的图像 3,3
    • Detach the white wire that is connected to the Wi-Fi card by applying gentle pressure.
    • Detach the black wire by applying gentle pressure.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 499
