跳转到主内容
Lenovo Yoga 910-13IKB Trackpad Replacement
你所需要的
  1. Lenovo Yoga 910-13IKB Trackpad Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo Yoga 910-13IKB Trackpad Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Trackpad Replacement, Battery: 步骤 2 中的图像 1,1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Trackpad Replacement: 步骤 3 中的图像 1,3 Lenovo Yoga 910-13IKB Trackpad Replacement: 步骤 3 中的图像 2,3 Lenovo Yoga 910-13IKB Trackpad Replacement: 步骤 3 中的图像 3,3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: 步骤 4 中的图像 1,3 Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: 步骤 4 中的图像 2,3 Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: 步骤 4 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove all six screws holding the trackpad to the device.
    • Find the ribbon cable, the black bundle of wires attached to the trackpad, and lift the head of the ribbon cable towards you.
    • Carefully lift up the trackpad and remove it from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 384
