跳转到主内容
Lenovo Yoga 910-13IKB Speakers Replacement
你所需要的
  1. Lenovo Yoga 910-13IKB Speakers Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Yoga 910-13IKB Speakers Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 2 中的图像 1,1
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 4 中的图像 1,1
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 5 中的图像 1,3 Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 5 中的图像 2,3 Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 5 中的图像 3,3
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 6 中的图像 3,3
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  7. Lenovo Yoga 910-13IKB Speakers Replacement, Speakers: 步骤 7 中的图像 1,2 Lenovo Yoga 910-13IKB Speakers Replacement, Speakers: 步骤 7 中的图像 2,2
    • Remove the four silver 3mm JIS #00 screws holding the speakers in place.
  8. Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 8 中的图像 1,2 Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 8 中的图像 2,2
    • Lift up the speaker from the corner of the device.
    • Pull gently on the bundled cable connector at the top of the speaker.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
  9. Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 9 中的图像 1,2 Lenovo Yoga 910-13IKB Speakers Replacement: 步骤 9 中的图像 2,2
    • Repeat step three for the speaker on the opposite side of the device.
结论
2等其他人完成本指南。
团队
Cal Poly, Team S1-G5, White Winter 2020 Cal Poly, Team S1-G5, White Winter 2020 的会员
CPSU-WHITE-W20S1G5
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 676
