这个步骤还没有翻译 帮忙翻译一下
Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
Pull the SSD stick directly to the right until it shifts out of place to remove it.
The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
这个步骤还没有翻译 帮忙翻译一下
Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
Remove the back connector strip using a wedge device to pry it off of the device
With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
即将完成!
终点
