跳转到主内容
Lenovo Yoga 910-13IKB SSD Replacement
你所需要的
  1. Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB SSD Replacement: 步骤 2 中的图像 1,1
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB SSD Replacement: 步骤 3 中的图像 1,1
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB SSD Replacement: 步骤 4 中的图像 1,1
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB SSD Replacement: 步骤 5 中的图像 1,3 Lenovo Yoga 910-13IKB SSD Replacement: 步骤 5 中的图像 2,3 Lenovo Yoga 910-13IKB SSD Replacement: 步骤 5 中的图像 3,3
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB SSD Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 910-13IKB SSD Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 910-13IKB SSD Replacement: 步骤 6 中的图像 3,3
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  7. Lenovo Yoga 910-13IKB SSD Replacement, SSD: 步骤 7 中的图像 1,1
    • Remove the 3mm JIS #00 screw holding the storage in place.
  8. Lenovo Yoga 910-13IKB SSD Replacement: 步骤 8 中的图像 1,2 Lenovo Yoga 910-13IKB SSD Replacement: 步骤 8 中的图像 2,2
    • Pull up lightly on the drive and gently pull it out of the connector.
结论
Nikhil Nagarajan
于01/23/20注册
97 声望
撰写一个指南
团队
Cal Poly, Team S1-G5, White Winter 2020 Cal Poly, Team S1-G5, White Winter 2020 的会员
CPSU-WHITE-W20S1G5
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 103
总计 5,667
