当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Using the Phillips #0 screwdriver, remove all six screws holding the trackpad to the device.
Find the ribbon cable, the black bundle of wires attached to the trackpad, and lift the head of the ribbon cable towards you.
Carefully lift up the trackpad and remove it from the device.
这个步骤还没有翻译 帮忙翻译一下
Remove the screws attached to the SSD stick with a Phillips #0 screwdriver.
Pull the SSD stick directly to the right until it shifts out of place to remove it.
Storage chip above it (further away from you) may also be detached by pulling it directly to the right until it clicks out.
3等其他人完成本指南。
