跳转到主内容
Lenovo Yoga 730-13IKB Storage Replacement
你所需要的
  1. Lenovo Yoga 730-13IKB Storage Replacement, Back Case: 步骤 1 中的图像 1,3 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: 步骤 1 中的图像 2,3 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: 步骤 1 中的图像 3,3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Storage Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 730-13IKB Storage Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 730-13IKB Storage Replacement: 步骤 2 中的图像 3,3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Storage Replacement: 步骤 3 中的图像 1,1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Storage Replacement, Storage: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 4mm screw holding down the storage drive.
  5. Lenovo Yoga 730-13IKB Storage Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 730-13IKB Storage Replacement: 步骤 5 中的图像 2,2
    • Hold onto the back of the storage drive and slightly lift up.
    • Remove the drive by pulling back at a diagonal angle.
    • To install the storage drive, insert it into the connector at a slight downwards angle. The drive connector is keyed and will only go in one way.
结论
另外一个人完成了本指南。
Colin Reay
于01/23/20注册
848 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, White Winter 2020 Cal Poly, Team S1-G1, White Winter 2020 的会员
CPSU-WHITE-W20S1G1
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 34
总计 1,390
