跳转到主内容
Lenovo Yoga 730-13IKB Back Case Replacement
你所需要的
  1. Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: 步骤 1 中的图像 1,3 Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: 步骤 1 中的图像 2,3 Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: 步骤 1 中的图像 3,3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Back Case Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 730-13IKB Back Case Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 730-13IKB Back Case Replacement: 步骤 2 中的图像 3,3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Back Case Replacement: 步骤 3 中的图像 1,1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
结论
Colin Reay
于01/23/20注册
848 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, White Winter 2020 Cal Poly, Team S1-G1, White Winter 2020 的会员
CPSU-WHITE-W20S1G1
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 29
总计 1,940
