此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
要重新组装设备,请按相反顺序执行这些说明。
15等其他人完成本指南。
4指南评论
Overall, this was very helpful: pictures were good, it took about the time proposed (I'm a newbie at this kind of thing), and since I had a 720 and a730 that both required new batteries, I bought the toolkit which really helped. I would add that, in the first step, where you're prying away next the hinges, there appear to be a some small 'nubs' between the hinges that hold the case in place. It doesn't mention it, but you have to work your way across between the hinges, to make sure it's loosened, otherwise the case won't come apart. Other than that, I found everything went exactly as described. I Fixed It, so thanks iFixit!
Great instructions mine only took 10 minutes to replace, but I 'm pretty handy.
5 or 10 minutes. Tool kit is great. Battery is perfect. Product design by Lenovo was excellent to allowsuch a simple battery change. David
david dodds - 回复 分享
