跳转到主内容
Lenovo Yoga 720-15IKB Wireless Adapter Replacement
你所需要的
  1. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: 步骤 1 中的图像 1,3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: 步骤 1 中的图像 2,3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: 步骤 2 中的图像 1,2 Lenovo Yoga 720-15IKB Wireless Adapter Replacement: 步骤 2 中的图像 2,2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: 步骤 3 中的图像 1,3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: 步骤 3 中的图像 2,3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: 步骤 3 中的图像 3,3
    • Lift the foam covering the connecting wires and screw, and use the Phillips #0 screwdriver to remove the 2mm screw.
  4. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: 步骤 4 中的图像 1,1
    • Grab the adapter from both sides and pull towards the hinge to remove the adapter from the device.
  5. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: 步骤 5 中的图像 1,1
    • Remove the black and white wires from the adapter by pulling up on each wire.
    • When reassembling, make sure to press each wire connector firmly onto the new adapter to make sure it is a secure fit.
结论
团队
Cal Poly, Team S19-G3, White Winter 2020 Cal Poly, Team S19-G3, White Winter 2020 的会员
CPSU-WHITE-W20S19G3
4 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 783
