跳转到主内容
Lenovo Yoga 720-15IKB Speakers Replacement
你所需要的
  1. Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: 步骤 1 中的图像 1,3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: 步骤 1 中的图像 2,3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Speakers Replacement: 步骤 2 中的图像 1,2 Lenovo Yoga 720-15IKB Speakers Replacement: 步骤 2 中的图像 2,2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: 步骤 3 中的图像 1,3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: 步骤 3 中的图像 2,3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: 步骤 3 中的图像 3,3
    • Here are the speakers for this device.
    • Pull the right speaker straight up and remove it from the computer.
    • As you remove the speaker, make sure to also carefully pull the wire connected to the speaker out along with the speaker.
  4. Lenovo Yoga 720-15IKB Speakers Replacement: 步骤 4 中的图像 1,1
    • Remove the left speaker similarly to how the right speaker was removed.
  5. Lenovo Yoga 720-15IKB Speakers Replacement: 步骤 5 中的图像 1,1
    • Unplug the speaker by firmly pulling the wire out of the socket.
结论
另外一个人完成了本指南。
Jeremy Kostel
于01/23/20注册
249 声望
创作了2篇指南
团队
Cal Poly, Team S19-G3, White Winter 2020 Cal Poly, Team S19-G3, White Winter 2020 的会员
CPSU-WHITE-W20S19G3
4 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 409
