简介
If the screen in the Lenovo Yoga 720-15IKB is not properly displaying images or is cracked, it may be time to replace it. Follow these instructions to replace the display in your laptop.
你所需要的
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
Remove the 6, 2.5x5 screws, located on the hinges of the underside of the device.
Separate the display from the back panel. The display should be away from the actual computer itself.
另外一个人完成了本指南。
一条评论
This method didn't work for me. The screen is stuck to the lid with tape that has to be pulled from the bottom in order to release the screen without breaking it. I had to buy a new screen with tape.
