跳转到主内容
Lenovo Yoga 720-15IKB Bottom Cover Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Start by flipping the device over so that you see the screws.
    • Remove the 7 T5 short screws.
    • Remove the 3 long T5 screws.
  2. Lenovo Yoga 720-15IKB Bottom Cover Replacement: 步骤 2 中的图像 1,2 Lenovo Yoga 720-15IKB Bottom Cover Replacement: 步骤 2 中的图像 2,2
    • Starting at the left USB port use you opening tool to gently pry up the bottom case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop's edge as shown by the arrows.
    • Do NOT pry along the top side, or you will damage the casing. Stay with the arrows.
  3. Lenovo Yoga 720-15IKB Bottom Cover Replacement: 步骤 3 中的图像 1,1
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the bottom case.
结论
dkay
于01/05/20注册
226 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 97
