你所需要的
Remove seven Torx T5 short screws.
Remove three Torx T5 long screws.
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
Use a Torx T5 screwdriver to remove the eight 8mm screws holding the touchpad in place.
另外一个人完成了本指南。
