跳转到主内容
Lenovo Yoga 720-12IKB Motherboard Replacement
你所需要的
  1. Lenovo Yoga 720-12IKB Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 3 中的图像 2,2
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 4 中的图像 1,2 Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 5 中的图像 1,1
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,1
    • The motherboard is located above the battery.
  7. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 7 中的图像 1,1
    • Unscrew and remove the 2.0 mm Phillips #00 screws.
  8. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 8 中的图像 1,2 Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 8 中的图像 2,2
    • Disconnect the connectors by lifting up the clip and pulling them out.
  9. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the 4.0 mm Phillips #00 screws from the fan.
    • Remove the 4.0 mm Phillips #00 screws from the heatsink.
  10. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 10 中的图像 1,2 Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the 5.5 mm Phillips #00 screws from the hinge.
    • Remove the 4.0 mm Phillips #00 screws froom the hinge.
    • Open the laptop a little to lift the hinge.
  11. Lenovo Yoga 720-12IKB Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard after all screws are out and connectors are disconnected.
结论
Alex Escobar
于02/10/22注册
778 声望
创作了6篇指南
团队
Gateway, Team 1-4, Pee Spring 2022 Gateway, Team 1-4, Pee Spring 2022 的会员
GCC-PEE-S22S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 365
