简介
This guide will show you how to remove the fingerprint reader.
你所需要的
在这个步骤中使用的工具:JIS Driver Set$19.99
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
在这个步骤中使用的工具:Spudger$3.99
6等其他人完成本指南。
一条评论
Aiden,
How do I repair the power button on this model? It no longer clicks and I have to use a paper clip on the opposite side. Looks like I need to remove the motherboard to gain access
