跳转到主内容
Lenovo Yoga 710-15ISK Motherboard Replacement
你所需要的
  1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
  2. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pry the back cover off of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the laptop.
  6. Lenovo Yoga 710-15ISK Motherboard Replacement, Fans: 步骤 6 中的图像 1,1
    • Remove the four 1.5 mm screws from the fans with a Phillips #00 screwdriver.
  7. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 7 中的图像 1,1
    • Unplug the wire connecting the fan to the motherboard by gently pulling the white head from the port.
  8. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 8 中的图像 1,2 Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift both fans to remove them from the laptop.
  9. Lenovo Yoga 710-15ISK Motherboard Replacement, SSD: 步骤 9 中的图像 1,1
    • Remove the sticker from the SSD to gain access to the screw underneath.
  10. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 10 中的图像 1,2 Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  11. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 11 中的图像 1,1
    • Slide the SSD out of the laptop.
  12. Lenovo Yoga 710-15ISK Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
  13. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 13 中的图像 1,3 Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 13 中的图像 2,3 Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 13 中的图像 3,3
    • Unplug four cables attached to the motherboard.
    • For the flat ribbon wires, lift the black tabs holding them in place before removing them.
  14. Lenovo Yoga 710-15ISK Motherboard Replacement: 步骤 14 中的图像 1,1
    • Carefully lift out the motherboard to remove it from the laptop.
结论
Annette Limoges
于10/25/21注册
181 声望
创作了2篇指南
团队
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G1
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 266
