简介
Solid state drives are known to fail occasionally, but this doesn't mean you have to do away with your laptop entirely. Replacing a bad drive is as simple as removing the battery and a single screw. Failure can be caused by heat, voltage fluctuation, and age.
  1. Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
    • Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
  2. Slide opening tool between the base and back cover.
    • Slide opening tool between the base and back cover.
  3. Lift back cover.
    • Lift back cover.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Remove the four 3.5 mm screws around the battery using the Phillips 00 screwdriver.
    • Remove the four 3.5 mm screws around the battery using the Phillips 00 screwdriver.
  6. Disconnect the battery from the motherboard.
    • Disconnect the battery from the motherboard.
  7. Gently lift and remove the battery.
    • Gently lift and remove the battery.
  8. Remove the one JIS 1 screw holding the solid state drive in place.
    • Remove the one JIS 1 screw holding the solid state drive in place.
  9. Gently pull the solid state drive out and up to remove it from the connector.
    • Gently pull the solid state drive out and up to remove it from the connector.
结论
2等其他人完成本指南。
Andrew Keenan
于2017年11月30日注册
149 信誉积分
撰写一个指南
团队
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 13
过去的30天: 94
总计 1,085
