跳转到主内容
Lenovo Yoga 710-15IKB Battery Replacement
你所需要的
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Battery Replacement: 步骤 2 中的图像 1,1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Battery Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Battery Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Battery Replacement: 步骤 6 中的图像 1,1
    • Gently lift and remove the battery.
结论
16等其他人完成本指南。
团队
2条评论
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - 回复
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 83
总计 18,763
