跳转到主内容
Lenovo Yoga 710-14ISK Battery Replacement
你所需要的
  1. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover screws: 步骤 1 中的图像 1,1
    • Remove the M2 × 7 mm, Torx-head screws.
    • Remove the M2 × 5 mm, Torx-head screws.
  2. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: 步骤 2 中的图像 1,2 Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: 步骤 2 中的图像 2,2
    • Insert a prying tool (opening pick) between the base cover and the cover and slide it in the direction shown by arrows to separate the base cover from the cover.
    • Remove the base cover.
  3. Lenovo Yoga 710-14ISK Battery Replacement, Remove the battery: 步骤 3 中的图像 1,1
    • Unplug the battery connector.
    • Remove the M2 × 3 mm, Phillips-head screws.
    • Remove the battery pack.
结论
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
于04/22/20注册
40,298 声望
创作了16篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,146篇指南
一条评论
Hi, do i can replace my laptop battery by myself? or i should go to geek squad in best buy.
Jesse Milani - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 631
