跳转到主内容
Lenovo Yoga 710-14IKB Wi-Fi Card Replacement
你所需要的
  1. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 1,3 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 2,3 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Peel off the black tape covering the top of the WiFi card.
    • Remove the black and white antenna cable attached to the card by pulling them off using the precison tweezers.
    • BE CAREFUL! The antenna socket is VERY FRAGILE. If you use brute force, the antenna socket on board (female) will be pull out with the male connector.
    • If you disconnect the antenna cable properly, the socket will remain undamaged like fig.3
  4. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: 步骤 4 中的图像 1,1
    • If you disconnect it with brute force, it will be damaged like that.
  5. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Use a #00 Phillips screwdriver to remove the 3mm screw in the center at the top of the card.
  6. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: 步骤 6 中的图像 3,3
    • The WiFi Card should be unbound from the surface. Carefully remove the card from the laptop by puling away from the socket.
结论
7等其他人完成本指南。
Grant Doerksen
于04/17/17注册
1,005 声望
创作了5篇指南
团队
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G5
4 名成员
创作了27篇指南
一条评论
I haven’t done it yet, but I’m no longer worried in the slightest! Your guide is about as dummy friendly as it gets, and I cannot even tell you how helpful your detailed instructions, ALONG WITH EXACT, CLEAR, and zoom-able pics of every step , PLUS warnings of what NOT to do and how to tell if you’ve screwed it up!!! A breath of fresh air compared what I’ve come to expect anymore online. I get ones like this - a super fast video, cam behind the person, too far away to see what they’re doing & how; The only zoomed-in shots are the before & after; No talking just background music ; Then in the description, where you expect their instructions, you get only stupidity… ie, like, “open laptop, remove wifi card.Put new one in the same way”. Wow, no sh**?! Idiots… Sadly, not exaggerated! So I just had to thank you, this is how it’s DONE! People should follow your example, something might get done (and done right) for a change!! Keep up the good work if this is ur thing! If not, it should be! Thanks again!
Teresa Allton - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 35
总计 3,610
