跳转到主内容
Lenovo Yoga 710-14IKB Speaker Replacement
你所需要的
  1. Lenovo Yoga 710-14IKB Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Speaker Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 710-14IKB Speaker Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 710-14IKB Speaker Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Speaker Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo Yoga 710-14IKB Speaker Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Speaker Replacement: 步骤 4 中的图像 1,2 Lenovo Yoga 710-14IKB Speaker Replacement: 步骤 4 中的图像 2,2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Speaker Replacement, Speaker: 步骤 6 中的图像 1,1
    • Locate the speaker's plug and disconnect it.
    • Follow the wires connected to the plug to locate the speakers. The left speaker will have red wires, and the right speaker will have blue wires.
  7. Lenovo Yoga 710-14IKB Speaker Replacement: 步骤 7 中的图像 1,2 Lenovo Yoga 710-14IKB Speaker Replacement: 步骤 7 中的图像 2,2
    • Untangle the wires from the plastic hinges of the case to properly lift the speakers out.
结论
Bailey Murphy
于11/01/18注册
85 声望
撰写一个指南
团队
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G8
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 741
